Mark.
Thanks, but.. Been there, done that.
The IDL color-limit works fine. Netscape 4.x supports color limiting via
the -ncols switch, but netscape 6 and MS iexplorer do not. We have an
'asp' application (memo class) that will not run under netscape 4.77 on our
Ultra30 creator3D workstation, with Solaris 8. So, the primary culprit
at this is the web browser and we're stuck with the color-gobbler type.
Is there a 'harder' way that you know of to lock-in specified RGB values?
-ps
----- Original Message -----
To: "'Paul Sichta '" <[email protected]>
Sent: Friday, April 20, 2001 11:10 AM
Subject: RE: medm & x-term color table
> Paul,
> I think the easiest solution to this problem is to restrict IDL and
netscape
> to use fewer colors. For IDL put the line
> idl.colors: 32
> for example in your .Xdefaults file.
> For netscape there is a similar setting or command line switch, though I
> forget what it is.
> Mark
medm & x-term color table Paul Sichta
Re: medm & x-term color table Ken Evans
<2001>
2025
2026
<2001>
2025
2026
