1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Fun with MAKE
To: "'[email protected]'" <[email protected]>
Date: Mon, 23 Apr 2001 08:03:03 -0700
> The right thing to do is to create a make dependency relationship between
> the .o file and the .h file.  This will cause make to update the .o file by
> recompiling the .st whenever the .h file changes.
> You can do this manually by editing entries into Makefile.Vx
> like this:
> snl_prog.o: some_header.h another_header.h yet_another.h
> For .c files, you can do this by using "make depend", which generates a
> file called DEPENDS in the O.<arch> directory which is then
> used by the makefiles.
Hello,
Perhaps this nugget could be added to the IOC source configuration
management guide - specifically here:
http://www.aps.anl.gov/asd/controls/epics/EpicsDocumentation/AppDevManuals/iocScm-3.13.2/buildingComponents.html#4_3_4
Stephanie Allison
Prev: RE: Fun with MAKE john sinclair
Next: tornado II john sinclair
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Fun with MAKE Peter Kurpis
