1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: tornado II
To: john sinclair <[email protected]>
Cc: tech talk <[email protected]>
Date: Mon, 23 Apr 2001 13:56:31 -0500
john sinclair wrote:
> I've just build R3.13.3 on a tornado II target and the following (from a
> st.cmd file) doesn't appear to work:
> appbin = "/usr/users/sinc2x86/orib30/bin/pc486"
> cd appbin
> This, of course, does work:
> cd "/usr/users/sinc2x86/orib30/bin/pc486"
> Am I missing some VxWorks kernel facility?
You're not trying to run the startup script using the host-based shell are
you?  While it may be possible to do so, I don't know of anyone who does
with EPICS, and this can (and probably will) cause problems like this
(prepending an '@' to some of the commands like '@cd' might help).  You'll
also need to set up symbol table synchronization between host and target.
It's probably much easier to configure and use the target shell instead.
- Andrew
Every great idea appears crazy to start with.
tornado II john sinclair
Prev: tornado II john sinclair
Next: RE: Fun with MAKE Peter Kurpis
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Is anyone using the VMIC 4100 module ?? Kristi Luchini
