Mark Rivers wrote:
> Here is an example from my st.cmd which works fine. Note that I don't call
> tyGSoctalModuleInit("GSIP_OCTAL232",0x80,0,0) at all. I guess initOctalUART
> does this? We are using MPF in our application.
Mark is using MPF, which has a different driver to the tyGSOctal one,
hence the different initialization. The tyGSOctal driver provides a true
vxWorks serial port which is accessed in the Unix manner by opening a file
descriptor, whereas MPF uses its own interface which was designed for
EPICS. "ipacAddCarrier" is the only initialization command that will be
common to both drivers.
- Andrew
Every great idea appears crazy to start with.
- RE: Problems with GSOctalRS232 Mark Rivers
gdct built with ivtools Carl Lionberger
<2001>
2025
2026
<2001>
2025
2026
