1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: gdct built with ivtools
To: Tim Mooney <[email protected]>
Cc: [email protected]
Date: Wed, 25 Apr 2001 13:04:43 -0700
At 1:56 PM -0500 2001/04/25, Tim Mooney wrote:
>The most irritating bug in gdct for us has been its tendency to replace
>record_name.<field_name> with record_name.VAL in links.  (The graphical
>link continues to point to the correct field, but the .db file doesn't
>agree.)  I have never determined the circumstances under which this
>occurs, because the replacement in not apparent until you try to run
>the .db file.  Have you guys run into this problem?
Yes, I have seen it; and I also cannot pin down the precise
circumstances that trigger it.
Also note that deleting a record sometimes visibly deletes but it still
exists in the .db; a "Hidden Record delete" is required; again, not
clear exactly what is the context.
The never-functional "Print" command disappeared with the R13 edition;
so did the very handy ability to import a straight .db and promote
it to graphical state (although you can still import and edit Hidden).
For those of you who have not tried GDCT in a long while, two features
were added over a year ago:
  -can remove as well as add exposed fields
  -can edit annotation text (had to delete/re-add before).  With the
   fix in the text-edit due to ivtools, this is more useful.
OK, JDCT folks: your turn to upgrade!
_____________________________________________________________________
Stephen A. Lewis                        | [email protected]
Mail Stop 71-259                        | http://www.lbl.gov/~salewis
Lawrence Berkeley National Laboratory   | Tel: +1.510.486.7702
Berkeley, CA 94720    USA               | FAX: +1.510.486.4544
Re: gdct built with ivtools Tim Mooney
Prev: Re: gdct built with ivtools Tim Mooney
Next: Re: gdct built with ivtools - bug Kristi Luchini
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
