1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Questions about the Multi-channel I/O Interrupt
To: <[email protected]>
Date: Wed, 9 May 2001 13:19:42 +0800
Hello, everyone. I have developed the acromagAVME9325 driver using I/O Intr
It's working well when one channel is used, no matter what's on other channels
 e.g.
record(ai, "$(user):aiAvme9325_Chan0")
 field(DESC, "Acromag AVME9325 Input")
 field(SCAN, "I/O Intr")
 field(DTYP, "acromagAVME")
 field(INP, "#C0 S0@")
 field(LINR, "LINEAR")
 field(EGUF, "10")
 field(EGUL, "-10")
 field(EGU, "Counts")
 field(HOPR, "10")
 field(LOPR, "-10")
 field(HIHI, "8")
 field(HIGH, "6")
 field(LOW, "4")
 field(LOLO, "2")
 field(HHSV, "MAJOR")
 field(HSV, "MINOR")
 field(LSV, "MINOR")
 field(LLSV, "MAJOR")
I tried to modify it with two channels like this:
 field(INP, "#C0 S0@")              /* channel 0 selected*/
 field(EGUF, "10")
 field(EGUL, "-10")
 field(HOPR, "10")
 field(LOPR, "-10")
 field(HIHI, "8")
 field(HIGH, "6")
 field(LOW, "4")
 field(LOLO, "2")
 field(HSV, "MINOR")
 field(LSV, "MINOR")
record(ai, "$(user):aiAvme9325_Chan1")
 field(INP, "#C0 S1@")           /* channel 1 selected*/
 field(EGUF, "10")
 field(EGUL, "-10")
 field(HOPR, "10")
 field(LOPR, "-10")
 field(HIHI, "8")
 field(HIGH, "6")
 field(LOW, "4")
 field(LOLO, "2")
 field(HSV, "MINOR")
 field(LSV, "MINOR")
This time I can't get the correct value of both channels, the two channels seems
have the same value. the ai read routine is like this:
long avme9325DI_read(register volatile unsigned short card,register volatile unsigned short chan,long *pval)
 register volatile avme9325_t **p;
 register volatile avme9325_t *pcard;
 p=AVME9325.pCardList;
 pcard=AVME9325.vmeAddrs;
 *p=pcard;
 if(!pval) return 1;
 if(chan>15) return 1;
 pcard->scanProg=0x80|(0x1F&chan); /* channel select*/
 pcard->conversionCount=0x01;      /* conversion times*/
 while(!(pcard->csr&0x80))
  } /*to determine whether the conversion finished*/
 *pval=(unsigned long)pcard->data[pcard->pData]>>4; /* read the AD value*/
 if(*pval==0xf000) return 1;
 else return 0;
I think there must be something wrong with the .db file, I have tried some ways such as add the PHAS field , or set the aiAvme9325_Chan1 to Passive scanning, but still doesn't work.
Any suggestion is appreciated. Thank you
Cheng Weixing from SSRF
RE: Questions about the Multi-channel I/O Interrupt Jeff Hill
Prev: RE: CA assert error on OSF1 version 5.1 Jeff Hill
Next: Newbie trying to move steppers in a CA client Chris Jacobsen
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: Questions about the Multi-channel I/O Interrupt Jeff Hill
