We use OSF1 v5.1 here at Fermilab. To solve this I added
-D_SOCKADDR_LEN to the command line.
Here are the notes from the send man page.
NOTES
[Tru64 UNIX] The send() function is identical to the sendto()
function
with a zero-valued dest_len parameter, and to the write() function if
no
flags are used. For that reason, the send() function is disabled when
4.4BSD behavior is enabled (that is, when the _SOCKADDR_LEN
compile-time
option is defined).
I also had to modify base/src/include/os/alpha/osiSock.h to handle the
disabling of the send() function (see note above). If this is not done
there are unresolved symbols at link time. Here are the lines I added
to osiSock.h for the alpha.
#undef send
#define send(A,B,C,D) sendto(A,B,C,D,NULL,NULL)
#undef recv
#define recv(A,B,C,D) recvfrom(A,B,C,D,NULL,NULL)
On OSF1 we have seen an assert error from a client app with a connected
channel when we reboot the processor on which the PV lives. Have you
seen this?
Geoff
"Rarback, Harvey" wrote:
> Folks,
> I am trying to build EPICS base 3.13.4 (Host only) on a Tru64 UNIX 4.0f platform. The build fails at
> cc -std1 -O -D_OSF_SOURCE -call_shared -DUNIX -I. -I.. -I../../../incl
> ude -I../../../include/os/alpha -c ../if_depen.c
> cc: Error: ../if_depen.c, line 62: In this statement, "sa_len" is not a member o
> f "pifreq->ifr_ifru.ifru_addr". (needmember)
> size = pifreq->ifr_addr.sa_len + sizeof(pifreq->ifr_name);
> The relevant source line is
> #if ( defined (BSD) && ( BSD >= 44 ) ) || defined ( SOCKADDR_HAS_LEN )
> if (size < sizeof(*pifreq))
> size = sizeof(*pifreq);
> #else
> Can some kind soul help me?
> --Harvey
> Harvey Rarback phone: (650)926-3963
> Stanford Linear Accelerator Center fax: (650)926-4100
> 2575 Sand Hill Road home phone: (650)560-9111
> Menlo Park, CA 94025
> [email protected]
> "I am a pitbull on the pantleg of opportunity."
> -George W. Bush
- RE: Build failure for if_depen.c Jeff Hill
- Build failure for if_depen.c Rarback, Harvey
<2001>
2025
2026
<2001>
2025
2026
