1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Attaching other interface after VxWorks boot
To: "Vladis Korobov" <[email protected]>, <[email protected]>
Date: Tue, 12 Jun 2001 09:17:46 -0600
If "ifShow()" on the slave does not list the ei interface then
you must call eiattach() to install the network interface
into the IP kernel. Next, call ifAddrAdd() to set the
interface's IP address. Next, call routeShow() to verify
that a route was installed for the new interface. If insufficient,
then call routeAdd() to specify the range of addresses that will
be delivered to the 2nd Ethernet.
Jeff
> -----Original Message-----
> From: Vladis Korobov [mailto:[email protected]]
> Sent: Tuesday, June 12, 2001 7:49 AM
> To: [email protected]
> Subject: Attaching other interface after VxWorks boot
> Hi all,
> I have 2 processors configuration: master is MVME167, slave is MVME162.
> VxWorks 5.3. The master is booted via Ethernet, the slave does via
> Shared Memory network.
> Is it possible for the slave anyhow after booting to attach
> one more Ethernet interface to other network, not connected to the boot
> network. See the fig.
>   boot Ethernet
>   |  ei  |    |      |   |
>   |      |    | Slave|   |another Ethernet
>   |Master|    | VME  | ? |
>   | VME  |    |    ei+---+
>   |  sm  |    |  sm  |   |
>  Has anybody such experience or any ideas, how to implement such scheme.
>  Thanks in advance,
>  V.Korobov
Re: Attaching other interface after VxWorks boot Andrew Johnson
Attaching other interface after VxWorks boot Vladis Korobov
Prev: Attaching other interface after VxWorks boot Vladis Korobov
Next: Re: Attaching other interface after VxWorks boot Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
