1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: bitwise severities on mbbiDirect
To: EPICS Techtalk <[email protected]>
Date: Mon, 18 Jun 2001 20:34:44 +0200
Carl Lionberger wrote:
> For some time there were fields for specifying the one severity, zero
> severity, and change-of-state severity for each bit (yes, 48 fields) in
> mbbiDirectRecord.dbd; as far as I know there was never any code for
> dealing with these fields in mbbiDirectRecord.c and now in 3.13.3 they
> have been removed from the dbd file.
> Do people think implementing these fields would be a good idea?   Did
> someone try it and decide it wasn't practical?  I'm working on the byte
> widget for edm and could support using them, and I could put them in the
> record too if  the whole idea doesn't seem unreasonable.  I guess a ca
> client would have to monitor each bit individually rather than just
> monitor VAL for the severity to get across on a bitwise basis?
I think the usual solution is to have soft bi records with their INP
link (with CPP attribute) pointing to each of the single bits of the
mbbiDirect.
With your proposal one could get rid of these bi records. On the other
hand, one looses the ability to give each bit a separate name,
description, etc.
Ben
bitwise severities on mbbiDirect Carl Lionberger
Prev: Support for HP8656B Vitaliy Vziskin
Next: Re: bitwise severities on mbbiDirect Brian McAllister
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: bitwise severities on mbbiDirect Carl Lionberger
