1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Minor problem with file names for genSub record CapFast symbols
To: "Redman, Russell O." <[email protected]>
Cc: "Saddlemyer, Les" <[email protected]>, "Dunn, Jennifer" <[email protected]>, "'\"Andy Foster\" <[email protected]>'" <[email protected]>, "Tech-Talk (E-mail)" <[email protected]>, [email protected]
Date: Mon, 25 Jun 2001 17:52:15 -0700
I sent this mail to Chuck Neal who will look into it
further and get back to you.
Chong Lee
Phase Three Logic
"Redman, Russell O." wrote:
> I have been attempting to use the genSub record in my databases (developed
> with SCHEDIT 3.10.2 for EPICS R3.13.4 using the Cygwin32 bash shell under
> Windows NT 4.01).  Until today I have not succeeded in getting a genSub
> record to survive the conversion from the CapFast schematic into the
> database.
> I have localized the problem to an unfortunate interaction between schedit
> and e2db.  The CapFast symbols for the genSub record all have file names
> with mixed case (egenSub.sym, etc.).  Schedit converts all the file names
> into lower case when they are written into the .sch files.  For most
> DOS/Windows programs this would be harmless, but e2db was written under Unix
> and demands an exact match between the symbol names in the .sch files and in
> the infamous edb.def file.  My records were being discarded because egensub
> does not match egenSub exactly.  (I have checked that the symbol file names
> have the correct cases in the epics.mnu file.)
> I suspect that this problem is unique to the PC version of CapFast, since
> the case of file names is always important under Unix whereas many DOS and
> Windows utilities fiddle the cases unpredictably.
> As a short term work-around, I have renamed all the genSub symbol file names
> in my installation into lower case, and have edited my epics.mnu files to
> suit.  With this minor change I can produce working records.  I am NOT
> suggesting that the genSub tar ball be modified in this way since it would
> probably break a fair amount of existing code developed on Unix platforms,
> but other EPICS programmers working on Windows platforms may find the record
> more useful knowing about this simple fix.
> On a longer time scale, I think it would be appropriate for CapFast under
> Windows NT and 2000 to preserve the original case for symbol names as given
> in the menu files, as it surely must under Unix.
> Cheers,
> Russell O. Redman
Minor problem with file names for genSub record CapFast symbols Redman, Russell O.
Prev: Minor problem with file names for genSub record CapFast symbols Redman, Russell O.
Next: Re: Mythili Srinivasan
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: SST-PFB-VME Roy Emerson
