1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: cac_recv_task
To: "Geoff Savage" <[email protected]>, <[email protected]>
Date: Tue, 10 Jul 2001 10:57:15 -0600
> We have a processor that has a task running the cac_recv_task function
> in vxWorks_depen.c that uses 99% of the cpu time.  What is this tasks
> purpose.  Under what conditions is this task started?  How do we avoid
> this condition?
This is the thread in the CA client library that receives network messages from
other hosts. I am guessing that you are experiencing a very high monitor
throughput into this client or possibly you have BSP configuration
resulting in a very high system tick rate. In R3.13 CA specifies the
following delay when this thread blocks in the select() system call.
		timeout.tv_usec = (4/*ticks*/ * USEC_PER_SEC)/sysClkRateGet();
		timeout.tv_sec = 0;
This delay in usec is computed as (4 ticks ) (sec/tick) (usec/sec). On most
vxWorks systems sysClkRateGet() returns 60 and the delay is computed to
be about 66 mS.
Jeff
cac_recv_task Geoff Savage
Prev: cac_recv_task Geoff Savage
Next: Tektronix TDS 3000, TDS 3EM, VXI-over-TCP/IP Carl Lionberger
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
