1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: R3.14.0alpha2
To: "john sinclair" <[email protected]>, "tech talk" <[email protected]>
Date: Fri, 13 Jul 2001 11:53:44 -0600
John,
When I received your message I was attempting to track down the
cause of very similar CA client library behaviors to what you
describe. They have been reported by others. I believe that I have
found the cause and have arrived at a fix that will show up in the
next beta release of R3.14.
Jeff
> -----Original Message-----
> From: john sinclair [mailto:[email protected]]
> Sent: Friday, July 06, 2001 6:49 PM
> To: tech talk
> Subject: R3.14.0alpha2
> I have been playing with R3.14.0alpha2 using a linux IOC with local
> clients.
> Kernel version: 2.2.16-22
> gcc version: 2.96 20000731
> glibc version: 2.2-5
> I have these env vars set
> EPICS_CAS_BEACON_ADDR_LIST=192.168.10.255
> EPICS_CA_AUTO_ADDR_LIST=no
> EPICS_CAS_INTF_ADDR_LIST=192.168.10.10
> EPICS_CA_ADDR_LIST=192.168.10.255
> EPICS_HOST_ARCH=linux-x86
> EPICS_TS_MIN_WEST=300
> EPICS_BASE=/epics/base
> LD_LIBRARY_PATH=/util:/epics/base/lib/linux-x86
> The connection and event delivery behavior seems somewhat erratic;
> sometimes there are substantial delays. Are there any special
> requirements on event callback functions?
> I never see any problems or delays when using a portable
> channel access server with R3.13.3.
> John Sinclair
> [email protected]
> Oak Ridge National Lab
> 865-576-6362   865-574-1268 (fax)
R3.14.0alpha2 john sinclair
Prev: LON-Bus Bernd Schoeneburg
Next: ICALEPCS EPICS Workshop Bob Dalesio
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: R3.14.0alpha2 john sinclair
Next: Channel Access under VxWorks (Power PC) amaudruz
