Section 2.3 (on pg. 15) of the EPICS Record Reference Manual (R3.13)
states: "A constant ... can be an integer value in whatever format (hex,
decimal, etc.) ...". I would like to use a hex constant as input to a
longin record, but can't get it to work. Has anyone used hex constants
successfully? We are using EPICS R3.13.4.
Here is the record description:
record(longin,"test:test") {
field(DESC,"long input record")
field(SCAN,"Passive")
field(PINI,"NO")
field(PHAS,"0")
field(EVNT,"0")
field(DTYP,"Soft Channel")
field(DISV,"1")
field(SDIS,"0.000000000000000e+00")
field(DISS,"NO_ALARM")
field(PRIO,"LOW")
field(FLNK,"0.000000000000000e+00")
field(INP,"0x0001")
field(EGU,"volts")
field(HOPR,"0")
field(LOPR,"0")
field(HIHI,"0")
field(LOLO,"0")
field(HIGH,"0")
field(LOW,"0")
field(HHSV,"NO_ALARM")
field(LLSV,"NO_ALARM")
field(HSV,"NO_ALARM")
field(LSV,"NO_ALARM")
field(HYST,"0")
field(ADEL,"0")
field(MDEL,"0")
field(SIOL,"0.000000000000000e+00")
field(SIML,"0.000000000000000e+00")
field(SIMS,"NO_ALARM")
Here is the record in the IOC:
-> dbpr "test:test",5
ACKS: NO_ALARM ACKT: YES ADEL: 0 ALST: 0
ASG: ASP: 0x00000000 BKPT: 0x00
DESC: long input record DISA: 0 DISP: 0
DISS: NO_ALARM DISV: 1 DPVT: 0x00000000 DSET:
0x00319dc8
DTYP: Soft Channel EGU: volts EVNT: 0 FLNK:CONSTANT
0
HHSV: NO_ALARM HIGH: 0 HIHI: 0 HOPR: 0
HSV: NO_ALARM HYST: 0 INP:CA_LINK 0x0001 NPP NMS
LALM: 0 LCNT: 0 LLSV: NO_ALARM LOLO: 0
LOPR: 0 LOW: 0 LSET: 0x002f9ea0 LSV: NO_ALARM
MDEL: 0 MLIS: 0x000000000000000000000000
MLOK: 0x002f9f3000000000 MLST: 0 NAME:
test:test
NSEV: NO_ALARM NSTA: NO_ALARM PACT: 0 PHAS: 0
PINI: NO PPN: 0x00000000 PPNN: 0x00000000 PRIO: LOW
PROC: 0 PUTF: 0 RDES: 0x002e1460 RPRO: 0
RSET: 0x00319744 SCAN: Passive SDIS:CONSTANT 0.000000000000000e+00
SEVR: INVALID SIML:CONSTANT 0.000000000000000e+00 SIMM: NO
SIMS: NO_ALARM SIOL:CONSTANT 0.000000000000000e+00 SPVT:0x00000000
STAT: UDF SVAL: 0 TIME: 0x0000000000000000
TPRO: 0 TSE: 0 TSEL:CONSTANT UDF: 1
VAL: 0
Note that EPICS thinks the INP field is a CA_LINK, not a CONSTANT. Any
help or advice would be appreciated. Thanks.
Russell Kackley
Joint Astronomy Centre
Hilo, Hawaii
Re: writing to non VAL fields Andrew Johnson
Re: Hex constant as input to longin record? Werner Portmann
<2001>
2025
2026
<2001>
2025
2026
