1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Apropos making fields configurable
To: "'Marty Kraimer'" <[email protected]>, Benjamin Franksen <[email protected]>
Cc: EPICS Techtalk <[email protected]>
Date: Fri, 20 Jul 2001 13:05:00 -0700
On Friday, July 20, 2001 11:53 AM, Marty Kraimer [mailto:[email protected]]
sent
> EOFF and ESLO cant be computed by softRaw support
> Russell Redman suggests that we add fields RAWL and RAWF.
> Instead of this why dont we just allow the user to assign values
> to ESLO and EOFF, i.e. just add promptgroup definitions to the dbd files.
I do not really want to add new fields, but my logic is as follows:
1) We do not need to assign values to EOFF and ESLO because the same
functionality is already available through the AOFF and ASLO fields.
2) The ranges of the raw and engineering units are both normally simple
numbers, easily understood by engineers and programmers.  For instance, the
voltage range [0.0, 5.0] volts may transform to raw counts [0, 4095].  The
slope, however is an awkward quantity ESLO=(EGUH-EGUL)/(RAWH-RAWL) =
5.0/4095 = 1.21001221001221e-3.
(Oops, I made a typo in that slope.  How many of you caught it just looking
at the number?)
EPICS applications will be more maintainable if the fields contain values
that are simple and physically meaningful.
Just out of curiosity, is there a reason why the variable "value" in convert
is set to 0.0 when LINR==LINEAR and ESLO==0.0, instead of just being left
alone?
Cheers,
Russell O. Redman
Re: Apropos making fields configurable Marty Kraimer
Prev: Re: Apropos making fields configurable Marty Kraimer
Next: [Fwd: socket errors] Geoff Savage
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Apropos making fields configurable Ralph . Lange
Next: Re: Apropos making fields configurable Marty Kraimer
