1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Apropos making fields configurable
To: EPICS Techtalk <[email protected]>
Date: Tue, 24 Jul 2001 18:32:03 +0200
Marty Kraimer wrote:
> Breakpoint table alarm problem when reaching end of table.
> Benjamin suggested adding a field BRSV.
> Instead of adding yet another field why not just change
>      recGblSetSevr(pai,SOFT_ALARM,INVALID_ALARM)
> to
>      recGblSetSevr(pai,SOFT_ALARM,MAJOR_ALARM)
> when cvtRawToEngBpt or cvtEngToRawBpt returns an error.
Because a field would give a lot more flexibility (what if I want e.g.
NO_ALARM?) at almost no cost (two bytes per analog record).
In principle, I agree that uncontrolled inflation of fields should be
avoided. But if additional fields bring a real advantage they should be
added. (Speaking economically, an inflation target of zero is definitely
*not* a good idea).
Only weakly related: Since alarm status is a menu (menuAlarmStat) but
has more than 16 entries, monitoring the STAT field of a record in
string representation gives incorrect results with the current CA
version (all values over 15 will be represented by an empty string). I
dearly hope this will be solved with the upcoming next version of CA!
Ben
Re: Apropos making fields configurable Ralph . Lange
RE: Apropos making fields configurable Redman, Russell O.
Re: Apropos making fields configurable Benjamin Franksen
Re: Apropos making fields configurable Marty Kraimer
Prev: Re: Apropos making fields configurable Marty Kraimer
Next: Re: Apropos making fields configurable Ralph . Lange
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
