Ian A Smith wrote:
> I would like to write a string to the FLNK field of a stringout record
> from my stringout device support. How can this be done?. The link will
> be connected to the INP of a stringin record.
It is not possible to directly modify link fields from record/device support
because of race
conditions related to lock sets. Only dbPutField, which must NOT be called from
record/device support, dynamically changes links.
A solution to your problem is to use a general purpose callback to issue the
dbPutField. Here is some skeleton code that will do it.
typedef struct myPvt {
CALLBACK callback;
struct dbAddr addr;
char destString[100];
}myPvt;
static void myCallbackFunc(CALLBACK *pcallback)
stringoutRecord *precord;
myPvt *pmyPvt;
callbackGetUser(precord,pcallback);
pmyPvt = (myPvt *)precord->dpvt;
dbPutField(&pmyPvt->addr,DBR_STRING,pmyPvt->destString,1);
The init_record device support routine would contain something like:
static long init_record(stringoutRecord *precord)
myPvt *pmyPvt;
char pvname[100];
long status;
pmyPvt = (myPvt *)dbCalloc(1,sizeof(myPvt));
callbackSetCallback(myCallbackFunc,&pmyPvt->callback);
callbackSetUser(precord,&pmyPvt->callback);
precord->dpvt = pmyPvt;
sprintf(pvname,"%s.FLNK",precord->name);
status = dbNameToAddr(pvname,&pxxxPvt->addr);
if(status) { ERROR THAT SHOULD NOT HAPPEN}
return(0);
When you want to write the string to the FLNK just say
callbackRequest(&pmyPvt->callback);
You have to decide how to give a value to destString.
Marty Kraimer
- newbie string q Ian A Smith
Retrieve network connection info through EPICS ? Brian McAllister
<2001>
2025
2026
<2001>
2025
2026
