not the solution, but maybe a hint:
i get the same error message under win2000 when i issue a caget command
from the command prompt as long as carepeater.exe is not running. caget
reports the UDP failure message, but also the correct PV value.
after carepeater started, whether automatically (by caget) or manually,
subsequent cagets report no error.
nor do i get any error when i use kay kasemir's activex client nor
direct ca.dll calls.
matthias muntwiler
university of zurich/ swiss light source
Geoff Savage wrote:
> Have any Win2000 users seen these errors? Is there some way to
> eliminate them?
> > David Huffman wrote:
> > Hi Geoff
> > Is there a chance you will get around to looking at the socket error I
> > get on NT machines.
> > It is just very annoying.
> > Dave
> > This is the error message.
> > Unexpected UDP failure WIN32 Socket Library Error 10054
- [Fwd: socket errors] Geoff Savage
Retrieve network connection info through EPICS ? Brian McAllister
Channel Archiver john sinclair
<2001>
2025
2026
RE: [Fwd: socket errors] Jeff Hill
<2001>
2025
2026
