1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Error Message
To: Andy Foster <[email protected]>, Tech-Talk <[email protected]>
Date: Wed, 01 Aug 2001 10:26:22 +0200
Hi Andy,
I did the changes for the mbufs in the file /target/h/net/mbuf.h (Tornado 1.0.1)
e.g.:
old:     #define NUM_INIT_MBUFS    40
new:                                                       100        (initial number
of mbufs, increased if necessary)
old:    #define MAX_MBUFS            1500
new:                                                   3000        (in fact this is
the main point)
After recompiling the vxWorks image you have it. (/target/src/config/usrNetwork.c uses
this defined parameters)
> I increased NUM_FILES to 150 but recently (with Tornado2.0.2 and
> EPICS 3.13.4), after an IOC has been running for sometime, I get error
> messages indicating that sockets can no
> longer be created. One of the things I was going to try was increasing
> the
> number of Mbufs. I wonder if you could tell me what you did in:
> I changed values in /target/h/netBufLib.h
> but was a little unsure of how to reconfigure things.
I couldn't reconstruct your idea to change values in /target/h/netBufLib.h ???
We are using vxWorks 5.3.1 , Tornado 1.0.1.
Zoltan
> Zoltan Kakucs wrote:
> > Hi,
> > we have had the same problem before years.
> > We decide to increase NUM_FILES to 255.
> > Additionally I've modified the Mbufs-Configuration to increase the network
> > performance. ( defaults in ../target/h/net/mbuf.h )
> > Regards,
> > Zoltan Kakucs
> > Robert Willson wrote:
> > > I have very recently been receiving this error message from my IOC, which
> > > repeats every few seconds:
> > > 0x758828 (CA TCP): CAS: Client accept error was "S_iosLib_TOO_MANY_OPEN_FILES"
> > > I can still run with this error, but I would like to know what might have
> > > caused it.
> > > IOC is MV167, EPICS v.3.13.2, VxWorks v.5.2
> > > -Robert Willson
> > > [email protected]
> Observatory Sciences Limited    Email: [email protected]
> William James House             Tel:  44 - (0)1223 - 508257
> Cowley Road                     Fax: 44 - (0)1223 - 508258
> Cambridge, CB4 0WX, UK          http://www.observatorysciences.co.uk
begin:vcard
n:Kakucs;Zoltan
tel;cell:+49-177-2412361
tel;fax:+49-40-89984388
tel;work:+49-40-89983283
x-mozilla-html:FALSE
org:DESY - Deutsches Elektronen-Synchrotron;Cryogenic Controls
adr:;;Notkestr. 85;22607 Hamburg;;;Germany
version:2.1
email;internet:[email protected]
title:BSc (Dipl.-Ing.)
fn:Zoltan Kakucs
end:vcard
Error Message Robert Willson
Re: Error Message Zoltan Kakucs
Prev: Which EPICS Makefile variable should I use? J. Frederick Bartlett ([email protected])
Next: ca assert Vladimir Sirotenko
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Error Message Dale L. Brewe
Next: VxWorks kernel configuration for GPIB Robert Willson
