1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Apropos making fields configurable
To: EPICS Techtalk <[email protected]>
Date: Mon, 06 Aug 2001 18:04:39 +0200
Andrew Johnson wrote:
> While I was away on vacation, Bob Dalesio wrote:
> > Also, the LINR field is an enum. Having it be an enum for
> > anything it finds and an arbitrary string if it is not
> > located, is not supported. When we connect to CA, the field
> > primatives cannot be mixed.
> LINR might be converted to a string field, which would allow the desired
> behaviour (and permit the addition of new breakpoint tables at run-time).
> Another problem with the enum is that it really should be dynamic
> according to the breakpoint tables actually loaded into the IOC, but it
> isn't.  However switching to a string will probably break some existing
> databases and displays, so I expect it to be rejected.
I have thought about a different solution. Reduce menuConvert to a fixed
set of general conversion methods, i.e. one of {NO CONVERSION, LINEAR,
BREAKPOINT, SUBROUTINE}. A separate (new) field of string type could
hold the name of the breakpoint table in case LINR is BREAKPOINT or the
name of a subroutine in case LINR is SUBROUTINE.
Ben
Re: Apropos making fields configurable Andrew Johnson
Re: Apropos making fields configurable Bob Dalesio
Prev: Re: Apropos making fields configurable Andrew Johnson
Next: VxWorks kernel configuration for GPIB Robert Willson
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Apropos making fields configurable Andrew Johnson
