1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: RAWF, RAWL
To: EPICS tech-talk <[email protected]>
Date: Tue, 14 Aug 2001 21:23:20 +0200
Andrew Johnson wrote:
> Marty Kraimer wrote:
> > Benjamin Franksen wrote:
> > > Does this mean that ESLO and EOFF will be made configurable?
> > I will add promptgroup(GUI_CONVERT) to both.
> > Question. What should special be?
> > It is currently defined as special(SPC_NOMOD). The question becomes. Should this
> > field be dynamically configurable. If we remove special(SPC_NOMOD) should we
> > define asl(ASL0)?
> Acording to the source for aiRecord.c, EOFF gets set to the value of EGUL
> at init time and every time a special(SPC_LINCONV) field is changed
> (before calling the dset->special_linconv() routine which may change it
> again), so the above makes no sense for EOFF.  The ESLO field is only set
> by device support, but if this field is made configurable then designers
> will set it when they don't need to, and then be surprised when their
> value is overwritten by any hardware device support at iocInit or when any
> special(SPC_LINCONV) field is modified.  This modification is not posted
> as a CA monitor, and this could cause confusion if we make ESLO
> modifyable.
> [...more justified reasons not to make ESLO and EOFF configurable...]
With my new proposal this problem could be solved, since in this case
LINR field will no longer have value LINEAR (but LINEAR_MANUAL or
whatever better name we agree on).
There are two possibilities:
(1) Assume (and demand!) that device supports check the LINR field to
see if it is LINEAR before they set ESLO and EOFF. I believe most of
them do. Add the check to the remaining ones.
(2) Forget the idea that device support sets EGUL and EGUF (instead of
ESLO and EOFF) if LINR==LINEAR_MANUAL. Call dset->special_linconv() only
in case LINR==LINEAR.
Ben
Berliner Elektronenspeicherring-Gesellschaft für Synchrotronstrahlung
(BESSY) GmbH, Control System Group
Albert-Einstein-Straße 15, 12489 Berlin, +4930 6392 8462, www.bessy.de
Re: RAWF, RAWL Andrew Johnson
RE: RAWF, RAWL Redman, Russell O.
Re: RAWF, RAWL Marty Kraimer
Re: RAWF, RAWL Benjamin Franksen
Prev: [Fwd: vxWorks, other ops] Rolf Keitel
Next: Re: RAWF, RAWL Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: RAWF, RAWL Andrew Johnson
