At SLS we have three solutions for monitoring temperatures in Epics:
Thermocouples connected to a Greenspring thermocouple industry pack on
a VME IP carrier - cost per channel ~ $102
Thermocouples connected to a Hytec instrumentation amplifier /ADC industry
pack - cost per channel ~ $70
A semiconductor temperature sensor (National semiconductor LM35 ~ -55oC
to 180oC, +/- 2oC accuracy +/- 0.5 oC resolution) giving ~ 10mV/oC directly
connected to our standard ADC - cost per channel ~ $95
All prices assume fully loaded crates and exclude cabling. The semiconductor
solution can often work out cheapest however as it uses standard low cost
twisted pair cable.
We have cable lengths of ~50m, to existing VME crates without problems,
but larger distances would also probably be fine if you want to reduce
the number of crates - but you need to trade off cable costs vs crate costs.
The total costs including VME crates, CPUs, and special (thermocouple)
cabling , based on your requirements, using 4 distributed crates, and an
average cable length of 20m, would be ~$120K.
Regards
Steve Hunt
"Rarback, Harvey" wrote:
Folks,
We need to monitor about 700 thermocouples for the SPEAR3 upgrade.
There will be about 40 TCs on 18 girders distributed around the 230m ring
circumference.
The present plan is to monitor the temperatures at a few second intervals.
We have a couple of quotes from PLC vendors, but they are fairly expensive.
Does anyone have a suggestion for hardware and software to accomplish
our task? Of course the aim is to get the temperatures into an IOC.
--Harvey
Harvey Rarback
phone: (650)926-3963
Stanford Linear Accelerator Center fax:
(650)926-4100
2575 Sand Hill Road
home phone: (650)560-9111
Menlo Park, CA 94025
[email protected]
- Re: How to monitor 700 thermocouples? Ralph . Lange
- MEDM display memory usage Robert Willson
- How to monitor 700 thermocouples? Rarback, Harvey
RE: An additional remark on C++ Jeff Hill
<2001>
2025
2026
Re: How to monitor 700 thermocouples? Paul Sichta
<2001>
2025
2026
