1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Problem talking CA across two CPUs in same crate???
To: EPICS Tech-Talk <[email protected]>
Date: Fri, 24 Aug 2001 09:41:50 -0700
Hello,
I am using EPICS R3.13.3 and I am using the sequencer.  There are
two Motorola PPC boards in my configuration.  One of which has
a sequencer within it (call it CPU1) and the other has PMAC
motor control (call it CPU2).  It appears that the sequencer
works fine with recorders within CPU1.  But for some reason
the sequencer process variables that are associated with
recorders in CPU2 cannot connect.  Both CPUs are plugged into
the same network also.
Are there any ideas what could be wrong with my configuration.
Oh yes I can get to all the process variables via the client
Sun workstation using caget, caput and camonitor calls.
All replies would be greatly appreciated.
Len
____________________________________________________
Leonard J. Reder
Jet Propulsion Laboratory
Interferometry Systems and Technology Section 383
Email: [email protected]
Phone (Voice): 818-354-3639
RE: Problem talking CA across two CPUs in same crate??? Jeff Hill
Re: Problem talking CA across two CPUs in same crate??? Ernest L. Williams Jr.
Prev: mbbiDirect/mbboDirect - why only 16 bits ? Brian McAllister
Next: Re: mbbiDirect/mbboDirect - why only 16 bits ? Brian McAllister
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: mbbiDirect/mbboDirect - why only 16 bits ? Brian McAllister
Next: RE: Problem talking CA across two CPUs in same crate??? Jeff Hill
