1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem talking CA across two CPUs in same crate???
To: Jeff Hill <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Fri, 24 Aug 2001 11:55:11 -0700
Jeff thanks so much.  I think everything is ok.  The ping
worked fine.  The routes are all set up ok.  The broadcast
address on the sun is:
hector:/home/keck/opt>/usr/sbin/ifconfig -a
lo0: flags=1000849<UP,LOOPBACK,RUNNING,MULTICAST,IPv4> mtu 8232 index 1
        inet 127.0.0.1 netmask ff000000
hme0: flags=1000843<UP,BROADCAST,RUNNING,MULTICAST,IPv4> mtu 1500 index
2
        inet 137.78.170.167 netmask ffffff00 broadcast 137.78.170.255
On both VxWorks CPUs it is the same.  I am running Tornado 1 kernels.
The casr 2 command returns:
btSeq>casr 2
Channel Access Server V4.8
No clients connected.
Client Name="", Client Host="", V4.0, Channel Count=0
        TId=0X16836C8, Protocol=UDP, Socket FD=14
        Secs since last send 64380.70, Secs since last receive 228.62
        Unprocessed request bytes=0, Undelivered response bytes=0
        Client's DNS Host Name histrionic:55292 State=up
        32928 bytes allocated
There are currently 308320 bytes on the server's free list
7 client(s), 512 channel(s), and 512 event(s) (monitors)
The server's resource id conversion table:
Bucket entries in use = 0 bytes in use = 16404
Bucket entries/hash id - mean = 0.000000 std dev = 0.000000 max = 0
Channel Access Address List
137.78.170.255:5065
value = 20 = 0x14
It looks very much the same for the other CPU with the PMAC motor
control.
Any other suggestions are greatly appreciated.
Len
Jeff Hill wrote:
> Len,
> Type "ping <CPU2's IP>, 10" on CPU1. If you don't get
> a response then there are low level problems with cabling,
> hubs, switches, arp, routes, etc. You can look at the routes
> by typing routeShow if you are familiar with this sort of thing.
> The routes on your sun can be seen for comparison purposes
> with "netstat -r". Your network sysadmin should be able to
> assist with this type of trouble.
> Type ifShow on your CPU1. Verify that the broadcast
> address listed for the LAN (not the loopback) interface
> matches what you see with "netstat -i" on your Sun.
> Next type "casr 2". You should see the above broadcast address
> in the CA address list diagnostic. If not, then your CA
> configuration is wrong or your version of EPICS is not
> compatible with Tornado II (the WRS SENS IP kernel).
> I believe that R3.13.3 _is_ compatible with Tornado 2.
> If the above check out ok then let me know and I will
> send you some additional diagnostics to try.
> Jeff
> > -----Original Message-----
> > From: Leonard J. Reder [mailto:[email protected]]
> > Sent: Friday, August 24, 2001 10:42 AM
> > To: EPICS Tech-Talk
> > Subject: Problem talking CA across two CPUs in same crate???
> > Hello,
> > I am using EPICS R3.13.3 and I am using the sequencer.  There are
> > two Motorola PPC boards in my configuration.  One of which has
> > a sequencer within it (call it CPU1) and the other has PMAC
> > motor control (call it CPU2).  It appears that the sequencer
> > works fine with recorders within CPU1.  But for some reason
> > the sequencer process variables that are associated with
> > recorders in CPU2 cannot connect.  Both CPUs are plugged into
> > the same network also.
> > Are there any ideas what could be wrong with my configuration.
> > Oh yes I can get to all the process variables via the client
> > Sun workstation using caget, caput and camonitor calls.
> > All replies would be greatly appreciated.
> > Len
> > ____________________________________________________
> > Leonard J. Reder
> > Jet Propulsion Laboratory
> > Interferometry Systems and Technology Section 383
> > Email: [email protected]
> > Phone (Voice): 818-354-3639
Leonard J. Reder
RE: Problem talking CA across two CPUs in same crate??? Jeff Hill
Prev: RE: Problem talking CA across two CPUs in same crate??? Jeff Hill
Next: Re: Problem talking CA across two CPUs in same crate??? Ernest L. Williams Jr.
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
