1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: portable ca server
To: john sinclair <[email protected]>, [email protected]
Date: Mon, 27 Aug 2001 10:00:24 -0600
At 07:21 PM 8/25/2001, you wrote:
>I noticed that my ca server does not respond properly when a
>ca_get_callback is called using DBR_GR_??? or DBR_CTRL_???, i.e. I don't
>send warning and alarm limits back properly. Instead, lower
>warning and alarm limits are populated by values for lopr.
>Upper limits get hopr. What do I do to fix this behavior?
Hello:
First the part that got me confused and I know from emails that I'm not the only one:
lopr, hopr, hihi, ... are epics record fields.
CA talks about display limits, alarm limits, ...
That's different.
When you ask an ai record fred for "fred",
the value is the VAL field, display limits are HOPR, LOPR,
alarm limits are HIHI, LOLO, warnings are HIGH, LOW, ...
So for ai, the "upper display limit" is the HOPR field?
Yes for the VAL fiels, No for the HHSV fields:
It's enumerated, ai.HHSV has values NO_ALARM, MINOR, MAJOR, INVALID
and display limits could be NO_ALARSM and INVALID.
I don't know what record fields are used for display limits etc.
when you attach a channel to e.g. the HIHI field,
you want e.g. control limits that allow for putting up
a slider that's useful for adjusting the HIHI field.
Read the record ref manual of the EPICS base sources
if you have to know what e.g. the high/low display limits
are for each field.
So I wouldn't be sure WHAT to provide in a home-grown
CA server, but as to HOW to provide it:
Your casPV-derived class has a
caStatus read (const casCtx &ctx, gdd &prototype)
method.
The prototype tells you what's requested:
Is it value, display limits,...?
If the client asked for DBR_CTRL_xxx,
the prototype will be a "container" of value, display limits, units,
alarm limits, warning limits, control limits.
base/src/cas/example/simple/exPV.cc has an example of how to handle all these
cases:
1) install a hash-table for dispatching all requests
   that you intend to handle:
void exPV::initFT()
        if (exPV::hasBeenInitialized) {
                        return;
        exPV::ft.installReadFunc ("status", &exPV::getStatus);
        exPV::ft.installReadFunc ("severity", &exPV::getSeverity);
        exPV::ft.installReadFunc ("seconds", &exPV::getSeconds);
        exPV::ft.installReadFunc ("nanoseconds", &exPV::getNanoseconds);
        exPV::ft.installReadFunc ("precision", &exPV::getPrecision);
        exPV::ft.installReadFunc ("graphicHigh", &exPV::getHighLimit);
        exPV::ft.installReadFunc ("graphicLow", &exPV::getLowLimit);
        exPV::ft.installReadFunc ("controlHigh", &exPV::getHighLimit);
        exPV::ft.installReadFunc ("controlLow", &exPV::getLowLimit);
        exPV::ft.installReadFunc ("alarmHigh", &exPV::getHighLimit);
        exPV::ft.installReadFunc ("alarmLow", &exPV::getLowLimit);
        exPV::ft.installReadFunc ("alarmHighWarning", &exPV::getHighLimit);
        exPV::ft.installReadFunc ("alarmLowWarning", &exPV::getLowLimit);
        exPV::ft.installReadFunc ("units", &exPV::getUnits);
        exPV::ft.installReadFunc ("value", &exPV::getValue);
        exPV::ft.installReadFunc ("enums", &exPV::getEnums);
        exPV::hasBeenInitialized = 1;
2) read is now simply
caStatus exPV::read (const casCtx &, gdd &protoIn)
        return this->ft.read (*this, protoIn);
That handles a simple "value" request as well as containers
3) implement all the elementary responses:
caStatus exPV::getValue(gdd &value)
caStatus exPV::getLowLimit(gdd &value)
-Kay
Re: portable ca server Benjamin Franksen
Prev: RE: portable ca server Jeff Hill
Next: Re: portable ca server Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: portable ca server john sinclair
