All,
This is a bug report for a problem discovered in EPICS R3.14,
EPICS R3.13, and possibly also EPICS R3.12.
Symptoms:
Clients disconnect unexpectedly when canceling event (monitor)
subscriptions using ca_clear_event(), but this may not be
noticed because the problem is probably rare under low or
moderate load, and because CA clients automatically
reconnect. The problem was only reproducible here under heavy
load presented when the R3.14 client side regression tests were
run on a fast Linux workstation. For example, when the tests
were run on a 500 MHz NT host I was unable to reproduce the bug.
On vxWorks you may see threads with the name "CA client" and also
"CA event" even if there are no clients connected (the casr
diagnostic will also incorrectly report that clients are connected).
As the IOC stays in long term operation without a reboot, and
depending on the frequency of occurrence at your site (if any), you
may also notice that memory and file descriptors are not reclaimed.
Fix:
I have committed a patch to CVS, and it will be incorporated
into the next release of R3.13 and also R3.14.
Background:
The problem was discovered when regression testing EPICS R3.14.
The cause was a deadlock occurring when a CA event (monitor)
subscription was canceled when the CA circuit was simultaneously
in event (monitor) flow control mode and the event (monitor)
subscription also had a corresponding update in the queue.
Sorry about any incontinence this has caused.
Jeff
__________________________________________________________
Jeff Hill Internet [email protected]
LANL MS H820 Voice 505 665 1831
Los Alamos NM 87545 USA FAX 505 665 5107 BEGIN:VCARD
VERSION:2.1
N:Hill;Jeff
FN:Jeff Hill
ORG:LANL;LANSCE-8
TITLE:Senior Software Engineer
TEL;WORK;VOICE:(505) 665-1831
TEL;WORK;FAX:(505) 665-5107
ADR;WORK;ENCODING=QUOTED-PRINTABLE:;MPF 398 Rm 108;MS H820=0D=0AP.O. Box 1663;Los Alamos;NM;87545;United States=
of America
LABEL;WORK;ENCODING=QUOTED-PRINTABLE:MPF 398 Rm 108=0D=0AMS H820=0D=0AP.O. Box 1663=0D=0ALos Alamos, NM 87545=0D=
=0AUnited States of America
EMAIL;PREF;INTERNET:[email protected]
EMAIL;INTERNET:[email protected]
REV:20010208T020805Z
END:VCARD
- RE: bug report Jeff Hill
Re: portable ca server Kay-Uwe Kasemir
<2001>
2025
2026
<2001>
2025
2026
