1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: IOSCANPVT
To: Jim Thomas <[email protected]>, [email protected]
Date: Wed, 19 Sep 2001 06:06:49 -0600
The granularity of the I/O Event scanning has always been in
the hands of the programmer.
While it is true that you could do make a seperate scan list
for each bit and that this would minimize the record
processing, you are trading this off against the length of
the scan list on the I/O even scanner and the checking of
the bits in the interrupt service routine. As the context
switch to the I/O event scanner is the real overhead, not
the record processing, it seems fine to put the granularity
equal to the granularity of the interrupt. I believe that
the binary records on a power PC take less than 1 usec each.
The context switch take over 30 usecs. It seems that the
code in the interrupt service routine would also be clearer
in the case where the events are posted once per card.
On the other hand, if the record processing chains that are
fired off for any of these bits is really horrendous, you
may want to have a seperate event for each bit.
Bob
IOSCANPVT Jim Thomas
Prev: IOSCANPVT Jim Thomas
Next: Re: IOSCANPVT Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
