1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: SubArray Record
To: Frank Lenkszus <[email protected]>
Cc: [email protected]
Date: Fri, 21 Sep 2001 08:18:33 +0900
Frank Lenkszus wrote:
> The 3.13 Record Reference manual pages for the SubArray record state that
> the field MALM is the "Maximum Number of Elements in the Sub-array". This is
> not true. If I wish to extract one element and only one element from a
> waveform record, and therefore the "Maximum Number of Elements in the Sub-array"
> is "1" the record support forces the INDX field to "0";i.e, I can never
> access any element greater than "0" From the record support code for  the
> Sub-Array record:
>         if (psa->indx >= psa->malm)
>            psa->indx = psa->malm - 1;
> The consequences of this is if one is required to blow out each and every
> element of an array into a separate process variable (Don't ask why - it's
> imposed on me by other considerations) MALM must be set to the input array size,
> not the "Maximum Sub-Array Size" which in this case is "1".  Since the record
> support allocates memory based on MALM, breaking up an N element array into N
> process variables means NxN memory locations will be allocated, even though only
> N elements will be used!  Not a problem for small arrays but when larger arrays
> are involved the memory consumption seems excessive.
> If this has been covered before, please excuse the noise.
We have developed a compact Subarray record to solve this problem. This
record requires a minor modification to the DB access library, though.
> Frank
Noboru Yamamoto
KEKB control group
KEK, JAPAN
SubArray Record Frank Lenkszus
Prev: SubArray Record Frank Lenkszus
Next: more subArray Record Geoff Savage
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
