1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: mvme162PA-344SE and mvme162-532A
To: "Dale L. Brewe" <[email protected]>, EPICS tech-talk <[email protected]>
Date: Tue, 02 Oct 2001 17:27:30 -0500
"Dale L. Brewe" wrote:
> As a backup for our mvme162-532A crate controllers, I'm thinking of
> purchasing an mvme162PA-344SE, which I'm told is a direct replacement. Can
> anyone tell me of any compatibility problems?
There is a 1-line change needed to the vxWorks BSP to use Petra-based
boards (MVME1xxP* parts) - if you don't make this network I/O can lock up
under high network loading.  The modified vxWorks image can be used with
the both types though.  I can provide the modification details to anyone
who needs them, to save having to search WRS's WindSurf for an SPR that
may no longer be there.
- Andrew
Perfection is reached, not when there is no longer anything to add,
but when there is no longer anything to take away.
- Antoine de Saint-Exupery
mvme162PA-344SE and mvme162-532A Dale L. Brewe
Prev: mvme162PA-344SE and mvme162-532A Dale L. Brewe
Next: does epics use the sysAuxClk interrupt? Peter Kurpis
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: mvme162PA-344SE and mvme162-532A Graham Waters
