1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Motor Record with Encoder
To: David Maden <[email protected]>, EPICS <[email protected]>
Date: Thu, 18 Oct 2001 16:41:40 -0500
Tim is correct.  If the URIP field is set to YES at boot-up
and the record pointed to by RDBL (i.e., the encoder record)
has it's STAT field set to UDF (undefined) when the motor
record is initialized, then the motor record reads zero from
RDBL and sets DVAL to zero.  (I recreated the problem using
V4.4 of the motor record, but I don't think that matters.)
David Maden wrote:
> when I boot the
> ioc, the motor record does not seem to pick up the initial value of the encoder
> and its DVAL field is zero. I do not seem to be able to restore the DVAL field
> of the motor at iocInit time via the save_restore mechanism.
Archive for Tech-Talk Leonard J. Reder
Re: Archive for Tech-Talk Marty Kraimer
Motor Record with Encoder David Maden
Prev: Motor Record with Encoder David Maden
Next: EPICS R3.13.4 Build question??? Leonard J. Reder
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Motor Record with Encoder Brian McAllister
