Leonard,
It would appear that ioctl(SIOCGIFCONF) returns errno six on your
system. This indicates "No such device or address". There are some
subtle difference in this io control between the IP kernels in Tornado
I and in Tornado II, but the call should be initially successful on
both OS. So I am confused. What do you see when you type ifShow on
your system? Is there any possibility that EPICS was built against
Tornado II header files and then loaded into a Tornado I system?
I have not tried this. Perhaps there would be undefined symbols.
A quick look at the source does not indicate why your shell is hanging.
The "exit" in the output below is probably a clue, but I don't see any
code that prints this message in R3.13. If you typed "exit" at a shell
prompt a hung ( non-existent ) shell would certainly result.
Otherwise to help us track down the hang please use "sp iocInit" instead
of "iocInit", and then use tt <task id> on the resulting task to
see where it is hanging. Usually the first task spawned with "sp" has
name t1 and so you can alternatively type "tt t1". Please e-mail the output
from tt.
Thanks
Jeff
> -----Original Message-----
> From: Leonard J. Reder [mailto:[email protected]]
> Sent: Thursday, October 18, 2001 4:15 PM
> To: EPICS Tech-Talk
> Subject: EPICS R3.13.4 Build question???
> Hello,
> I was using R3.13.3 but with our systems upgrade to Solaris 2.8
> I decided to build R3.13.4. It seemed build fine! with Tornado 1
> tools. I have to use Tornado 1 for now. I am seeing the following
> error messages after the iocInit is executed and then the VxWorks
> shell hangs. Does anyone have any ideas about this problem or how
> I can fix it?
> Thanks,
> Len
> SCREEN DUMP STARTS:
> sysClkRateSet( 200 )
> value = 0 = 0x0
> iocInit
> St### arting iocInit
> @(#)EPICS IOC CORE built on Oct 15 2001
> ### @(#)Version R3.13.4 $2000/12/15 15:52:33$
> Failed to set clock from Unix server
> CAC: SIOCGIFCONF ioctl failed because 6
> value = 0 = 0x0
> exit
> iocInit: All initialization complete
> osiSockDiscoverInterfaces(): unable to fetch network interface
> configuration
> Done executing startup script
> /home/keck/reder/kroot/kss/if/to/startup/O.mv2304/dsmTest
> ____________________________________________________
> Leonard J. Reder
> Jet Propulsion Laboratory
> Interferometry Systems and Technology Section 383
> Email: [email protected]
> Phone (Voice): 818-354-3639
- Re: EPICS R3.13.4 Build question??? Leonard J. Reder
- EPICS R3.13.4 Build question??? Leonard J. Reder
Re: Motor Record with Encoder Brian McAllister
<2001>
2025
2026
<2001>
2025
2026
