>>> On 10/23/2001 at 15:59:09 +0200, David Maden wrote:
> the key to the solution is to note that writing to the VAL field of the
> motor record when it is in "SET" mode will cause it to pick up values
> from its RDBL field.
> 2) The actual value written to the VAL field is not particularly
> critical. It must, however, lie within the LLM to HLM range of the
> motor.
I realized after I wrote my previous note that writing to VAL is not
required, but rather causing the record to process while in SET mode.
Writing to VAL is a simple way to do that, but one can also use .PROC, or
an FLNK, etc.
Brian McAllister Controls Programmer/Beam Physicist
[email protected] MIT-Bates Linear Accelerator
(617) 253-9537 Middleton, MA
- Summary: Motor Record with Encoder David Maden
dm2k & NT/X-Win mem leak? Laznovsky, Michael
<2001>
2025
2026
XYCOM XVME 203 Counter Module w/ Quadrature Kristi Luchini
<2001>
2025
2026
