It sounds like there is a problem with the communication between the DCM and
your IOC.
Do the following (All via the vxWorks shell)
dbpf "<dcm record>.TPRO","1"
What does it show? Does it show active for 8 seconds spans? I will guess yes.
Now type
dbior "drvAb",3
On the link that has the DCM look at the first part. You should see something
like:
AB-6008SV link: 1 osw 002c vme: 0xf0c01000
6008SV2R Scanner Series A Revision A Copyright (c) 1995 Allen-Bradley
Company
Mailbox lock timeouts 0
Command timeouts 1
Command Failure 0
Interrupts per second 13
Block Transfers per second 6
Adapter Status Words
1f20 0000 0000 0000 1d20 0000 0000 0000
0000 0000 0000 0000 0000 0000 0000 0000
scan list
00 04
Adapter 0 ONLINE 1 slot addressing
CARD 0: BT Scanning abDcm
Do you see an excessive number of command timeouts and/or failures?
Also do a
dbpr "<dcm record>",3
dbpr "<bi record>",3
Where <bi record> is the record you are looking at on the dm2K screen.
I would like to see these.
Marty Kraimer
Zheng Lifang wrote:
> Dear all,
> I have been testing a Protecting System similar to APS's, which has three levels. The first is a VME crate plugged with a MVME2302/IOC, a SV2R6008 scanner. The second is a AB crate plugged with a 1771DCM, a PLC5/40, a 1771SDN and two I/O local modules. The third is a 1794ADN which controls a 1794IB16 & a 1794OB16.
> The first success should contribute to much help from Prof.M.Kraimer, Dr.A Johnson and Dr.
> Now I meet some other questions. I use Rockwell RSlogix 4.11.00 revision to program PLC.
> local input: I:010
> DCM read buf: N10:0
> DCM write buf: N10:64
> SDN read buf: N11:0
> When PLC sends data(block transfer) to DCM, the tag is set to 0 or 1 to distinguish the data from local I/O or from DeviceNet FlexI/O.
> The rung orders are:
> copy I:010 to N10:66
> set N10:65=0 (tag=0)
> BTW to DCM (l=64)
> BTR read data to N11:0 from DeviceNet(l=62)
> copy N11:1 to N10:66
> set N10:65=1 (tag=1)
> BTW to DCM
> I use DM2K to display and there occur two problems.
> 1)Occasionally there is some exchanging data between local I/O and DeviceNet I/O.
> 2)When I change the local or FlexI/O input module states, there is unbearable delay in DM2K to update. When I use .5second to process abDCM record, the delay is nearly 8 seconds.
> Any suggestion is welcome.
> Lifang
- Ladder logic programing for PLC Zheng Lifang
An et_wish crash Andy Foster
<2001>
2025
2026
<2001>
2025
2026
