shen guobao wrote:
>Hello,everyone,
>When I compile CDEV 1.7.5 in WIN-NT,there is an error:
>=> Objects: caChannel.obj caNameSvc.obj caRequestObject.obj caService.obj >caMonObj.obj caMisc.obj
>LINK : fatal error LNK1181: cannot open input file "\base\lib\ca.lib"
There are no EPICS and EPICSLIB environment variables set on your
Windows machine. Please check your epics installation on your Windows
environment.
>And when I compile it in SUN/Solaris2.7,VxWorks5.3.1/EPICS3.13.1,
>there is another error:
>=> Compiling directory >/ssrf/project/master/epics/R3.13.1/extensions/src/cdev_1.7.5/src/lib
>gmake[2]: *** No rule to make target `.obj/solaris-gnu/cdevDirectory.o', needed by >`../../lib/solaris-gnu/libcdev.a'. Stop.
>gmake[1]: *** [solaris-gcc] Error 2
><= Done...
Did you run configure script inside cdev/src directory? The configSvc
script inside the cdev/src directory will create Makefile for
cdev/src/directory
directory. Without the Makefile in the directory, the cdevDirectory.o
will not be generated before you compile the libcdev.a library.
Let us know if you have any problems. Thanks.
Jie Chen
Thomas Jefferson National Accelerator Facility
12000, Jefferson Ave.
Newport News, VA 23606
(757)269-5046 (office) (757)269-6248 (fax)
[email protected]
- Re: Help about compile CDEV shen guobao
XCas Benjamin Franksen
RE: The "scanppl" command only works once Kevin Tsubota
<2001>
2025
2026
<2001>
2025
2026
