1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: PowerPC woes
To: "Kevin Tsubota" <[email protected]>, "'Nick Rees'" <[email protected]>, "Mark Rivers" <[email protected]>, "Andrew Johnson" <[email protected]>
Cc: "EPICS-tech-talk" <[email protected]>
Date: Mon, 19 Nov 2001 09:39:51 -0700
Another possible cause of this problem could be that
a boot was interrupted while in progress. If the IOC
comes up and tries to reuse the same TCP port the
Solaris server sometimes waits a very long time before
it times out the old TCP circuit and begins communicating
with the IOC which is presenting TCP sequence numbers
that are invalid in the Solaris FTP server's perspective.
Jeff
> -----Original Message-----
> From: Kevin Tsubota [mailto:[email protected]]
> Sent: Friday, November 16, 2001 3:03 PM
> To: 'Nick Rees'; Mark Rivers
> Cc: '[email protected] '
> We had a similar problem when booting our MV2304's where it would
> take an extremely long time to boot.  After messing with the ethernet
> settings we finally settled on changing from using rsh to tftp when
> booting our crates:
> 	ftp password = blank
> 	flags		 = 0x88
> Of course this means you need to have your host setup to support tftp.
> In our case our hosts are Solaris workstations.
> Kevin Tsubota
> > From: Nick Rees [mailto:[email protected]]
> > Sent: Friday, November 16, 2001 10:39 AM
> > To: Mark Rivers
> > On Fri, 16 Nov 2001, Mark Rivers wrote:
> > > I have a different suggestion from Andrew's.  I have seen a
> > very similar
> > > problem to the on Nick describes on the MVME2700.  The
> > problem is actually
> > > with the Ethernet 10/100 autonegotiation.  If I plug the
> > Ethernet into a
> > > 10/100 Hub it works fine.  If I plug it into certain types
> > of Ethernet
> > > switches (e.g. Cisco 2924 I think) it takes several
> > minutes, and it does it
> > > twice as Nick observed. Try using a different physical
> > device and see if it
> > > improves.
> > I have tried four configurations:
> > 1. An autoconfiguring 10/100 switch (Allied Telesyn),
> > 2. An autoconfiguring 10/100 hub (SMC)
> > 3. A fixed 10 base T switch (Allied Telesyn)
> > 4. A fixed 100 base TX hub (Allied Telesyn).
> > All with no result. Sob. Sob.
> > I have also tried changing the address translation stuff as
> > per Andrew's
> > suggestions, but to no avail. However, I may have got it
> > wrong, so I will
> > continue to think about it.
> > Cheers,
> > Nick Rees
> > Joint Astronomy Centre               Ph:       +1 (808) 961-3756
> > 660 N. Aohoku Place                  Fax:      +1 (808) 961-6516
> > Hilo, HI.  96720                     Internet: [email protected]
RE: PowerPC woes Kevin Tsubota
Prev: RE: PowerPC woes Kevin Tsubota
Next: Fwd: RE: PowerPC woes Dale L. Brewe
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
