1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EPICS 3.13.1 (and earlier) - NTP issues
To: [email protected]
Date: Tue, 20 Nov 2001 16:29:29 -0500
Folks -
Last month we discussed the bug in EPICS NTP support that caused the IOC
time to fall behind in 10 second increments.  This bug was fixed in
3.13.2.
At that time, I wrote that the only operational fix was to reboot the
IOC. As this is often inconvenient, I offer a somewhat less intrusive
solution.
As the problem has to do with NTP requests becoming out of sync with the
replies, it occurred to me that disconnecting the IOC from the network
would cause the queued (old) replies to be read as responses to subsequent
requests, while no new replies would be received.
Thus, the solution is to unplug the network connection and wait for
(amount_of_time_the_IOC_clock_is_slow + 15-20 seconds), by which time the
IOC will have emptied the receive queue.  On reconnecting the network, the
time will be correctly re-synced by the subsequent NTP transactions.
While this interruption in service may still not be acceptable, at least it
involves less time and disruption than rebooting.
Brian McAllister                    Controls Programmer/Beam Physicist
[email protected]                        MIT-Bates Linear Accelerator
(617) 253-9537                                           Middleton, MA
Prev: Re: increasing the number of file descriptors Andrew Johnson
Next: Re: An et_wish crash EPICS User
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Can EPICS be used in Tokamak? Happy
