1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: save_restore Query
To: [email protected]
Date: Tue, 4 Dec 2001 13:11:44 -0600 (CST)
The stuff Ned suggested you insert in your st.cmd file were added to
save/restore locally quite awhile ago. I'm not sure these changes made it
into what you're using. From the README file:
                                                F. Lenkszus  8/6/97
This note describes changes made to the autosave-restore package.
The following functions have been added:
dbrestore.c
        set_pass0_restoreFile( char *filename)
        set_pass1_restoreFile( char *filename)
save_restore.c
        set_savefile_path(char *path)
        set_requestfile_path( char *path)
        set_saveTask_priority(int priority)
        remove_data_set( char *filename)
        reload_periodic_set(char * filename, float period)
        reload_triggered_set(char *filename, char *trigger_channel)
        reload_monitor_set(char * filename, float period)
        reload_manual_set(char * filename)
        fGetDateStr( char datetime[])
        fdbrestoreX( char *filename)
Description of new features:
(Description deleted)
Frank
Prev: Re: save_restore Query Ned Arnold
Next: Channel Archiver on HP-UX 11.0 Noboru Yamamoto
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
