Benjamin Franksen wrote:
> Hello all,
> the Record Reference Manual states that UDF field may be modified and
> even is PP. However, whenever I put some value (1) to UDF field of a
> passive soft ao record (in order to indicate that the record's value is
> undefined now), the record's status / severity do not become UDF_ALARM,
> INVALID_ALARM but remain whatever they are. Subsequent queries of the
> UDF field give the value 0 insted of 1, although no writes to the VAL
> field happen in between.
> Using a dbLink with PP property gives the same results.
> Looking at aoRecord.c and even dbAccess.c, I found no reason for this.
> What am I missing?
This should work. I tried it on soft records and it works just fine.
The test database is
record(ao,"mrkjunk")
record(ao,"mrkjunk1")
field(OUT,"mrkjunk.UDF PP")
The test is
epics> dbpr "mrkjunk"
ASG: DESC: DISA: 0 DISP: 0
DISV: 1 NAME: mrkjunk OMOD: 0 OVAL: 1
RBV: 0 RVAL: 1 SEVR: NO_ALARM STAT: NO_ALARM
TPRO: 0 VAL: 1
epics> dbpf "mrkjunk1","1"
DBR_DOUBLE: 1
RBV: 0 RVAL: 1 SEVR: INVALID STAT: UDF
TPRO: 0 VAL: 1
Question. What device support is attached to your ao record?
Note that record support only checks the ufd field after it calls device
support.
Does your device support set ufd 0?
Marty Kraimer
- Re: put to UDF Benjamin Franksen
- put to UDF Benjamin Franksen
Re: Platform independent Gui toolkits Korhonen Timo
<2001>
2025
2026
<2001>
2025
2026
