John--
You raise some issues which I for one cannot answer. But let me point you
to the GPL FAQ again and give some excerpts which may answer some of your
questions:
http://www.gnu.org/licenses/gpl-faq.html
Q. If a program released under the GPL uses plug-ins, what are the
requirements for the licenses of a plug-in.
A. It depends on how the program invokes its plug-ins. If the program
uses fork and exec to invoke plug-ins, then the plug-ins are
separate programs, so the license for the main program makes no
requirements for them.
If the program dynamically links plug-ins, and they make function
calls to each other and share data structures, we believe they
form a single program, so plug-ins must be treated as extensions
to the main program. This means they must be released under the
GPL or a GPL-compatible free software license.
If the program dynamically links plug-ins, but the communication
between them is limited to invoking the `main' function of the
plug-in with some options and waiting for it to return, that is a
borderline case.
Q. Can I use the GPL for a plug-in for a non-free program?
A. If the program uses fork and exec to invoke plug-ins, then the
plug-ins are separate programs, so the license for the main
program makes no requirements for them. So you can use the GPL for
a plug-in, and there are no special requirements.
to the main program. This means that linking the GPL-covered
plug-in with the main program would violate the GPL. However, you
can resolve that legal problem by adding an exception to your
program's license which gives permission to link it with the
non-free main program.
For more details, see the question above that starts with, "I am
writing free software that uses a non-free library."
> There are too many complications here to make this issue a trivial
> one.
Agreed. Ultimately, these are issues which won't be resolved on this
listserve and likely will require real legal counsel.
Steve Hartman
[email protected] | 919-660-2650
Duke Free Electron Laser Laboratory
- Re: Software Licensing; the GNU GPL and EPICS john sinclair
Re: Error messages wuth IP-488, VIPC616 and PPC604 Maren Purves
<2001>
2025
2026
Re: Software Licensing; the GNU GPL and EPICS Benjamin Franksen
<2001>
2025
2026
