1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Error messages wuth IP-488, VIPC616 and PPC604
To: "'J. Frederick Bartlett ([email protected])'" <[email protected]>, Mark Rivers <[email protected]>
Cc: [email protected]
Date: Thu, 27 Dec 2001 10:46:47 -1000
I am also experiencing these "Bad VME interrupt 0" messages while
using VIPC618 carrier boards with an IP330 module in slot D and a MV2304
CPU.
I'm only now starting to look into this problem, but the messages I get seem
spurious and so far isolated to a single VME crate.  I will keep you posted.
> -----Original Message-----
> From: J. Frederick Bartlett ([email protected])
> [mailto:[email protected]]
> Sent: Monday, December 24, 2001 1:06 PM
> To: Mark Rivers
> Cc: [email protected]; [email protected]
> Subject: Re: Error messages wuth IP-488, VIPC616 and PPC604
> Mark Rivers encountered the following problem:
> > In a new EPICS application I am talking to several GPIB
> devices each at 10
> > Hz, and I am getting swamped with "Bad VME interrupt 0"
> error messages.  The
> > problem happens when using the SBS (Greenspring) IP-488
> module, mpfGpib1-4,
> > VIPC616 carrier, and an MVME2700 PPC CPU.  Andrew Johnson
> suggested removing
> > the logMsg() call in target/config/mv2700/universe.c that
> generates the
> > error.  While this would work, I am getting nearly 100
> messages per second,
> > and I worry that all these spurious interrupts could be
> hurting performance.
> Mark,
>   This may be similar to a problem that I encountered when I moved an
> EPICS system from a MVME2301 to an MVME2304. I also saw the "Bad VME
> interrupt 0" error message on the MVME2304 but not on the MVME2301.
>   When I consulted our local vxWorks expert, Dave Berg, here at
> Fermilab, he suggested that it might be the result of the
> execution-time optimization that occurs in the 604 processor chip --
> the MVME2301 has the 603 processor chip. I note that the MVME2700
> series uses the 750 processor chip and I do not know whether it also
> uses execution-time optimization.
>   Briefly, run-time optimization can result in instructions being
> executed in a different order than they appear in memory. Normally
> this is not a problem because the processor chip only reorders
> instructions that it considers to be independent. However, since it
> sees only the local memory bus, there is no means for it to determine
> that the register being accessed is, in fact, mapped to a hardware
> device that may be sensitive to the order of its register accesses.
>   This was apparently what happened with our device where the register
> access that cleared the interrupt request was being delayed until just
> before (or even after) exiting the interrupt service routine. This
> produced an unexpected interrupt since the VME interrupt request line
> was still active when the processor priority dropped to a lower level
> than the interrupt priority. The problem was alleviated by forcing the
> processor to execute the write access to the device register via the
> addition of a dummy read access of the same register immediately
> following the write access. The optimizing logic recognized that the
> write access must be executed first in order for the read access to be
> valid.
>   I intend to ask Motorola whether there is some means of temporarily
> inhibiting the run-time order optimization of these processors and I
> will report the results to tech-talk.
>   Perhaps you have encountered a similar problem with the 750
> processor chip.
> 						Fritz
Prev: Re: Help about CORBA Leonard J. Reder
Index: 1994  1995  1996  1997  1998  1999  2000  <20012002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Error messages wuth IP-488, VIPC616 and PPC604 J. Frederick Bartlett ([email protected])
Next: Re: How to get EPICS ? Maren Purves
