1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: VXI driver support
To: [email protected]
Date: Tue, 8 Jan 2002 11:05:29 -0700
Andrew Johnson wrote:
Could there be a problem with using logical address 1?
Try switching to a logical address above 0x40
That was the solution.
Jeff Hill wrote:
Andrew Johnson made source code changes to ifdef out the auto
initialization of the nivxi library in recent versions of drvEpvxi.
I'm using drvEpvxi.c v1.7 and the NICPU030 symbol is defined by default.
Thanks!
RE: VXI driver support Jeff Hill
Re: VXI driver support Andrew Johnson
Prev: Re: iocsh for Epics314b1 on win32 kuner
Next: Use of ethernet-controlled devices in EPICS Robert Willson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: VXI driver support Jeff Hill
