1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: channel access reboot behavior
To: <[email protected]>
Cc: <[email protected]>
Date: Mon, 14 Jan 2002 09:53:01 -0500
Brian,
As Jeff indicated,  we have certain device drivers that will
usually hang the 'reboot' process.  We use a macro to first
delete the driver tasks (preceded by a spy and casr listing
to display system info), delay a bit, and then issue the
'reboot' command as the last line.
IOCx>  <st.shutdown_iocx
Paul Sichta
Princeton Plasma Physics Laboratory
609-243-3477       FAX 3030
----- Original Message -----
Sent: Friday, January 11, 2002 6:58 PM
Subject: channel access reboot behavior
> As currently implemented, Channel Access on the IOC tries
to communicate
> with remote clients/servers when shutting down prior to
reboot (this is
> inferred from error messages seen during the shutdown).
Unfortunately,
> network services will always have been shut down first, so
these
> notification attempts always fail, and will continue to do
so unless the
> VxWorks reboot processing is modified to allow user hooks
to be handled
> first, which seems unlikely.
> Occasionally, one of our IOCs will hang on reboot,
requiring physical
> access to push the reset button.  I am wondering if this
hang might in part
> be due to the system trying to do things while in a
partially shut down
> state, and if there is any reason not to eliminate the CA
server behavior
> noted above, on the chance that it may be contributing to
the problem.
> Or perhaps, EPICS could have a "shutdown" routine, which
terminates the
> EPICS tasks appropriately, and then calls reboot ?
> Brian McAllister                    Controls
Programmer/Beam Physicist
> [email protected]                        MIT-Bates Linear
Accelerator
> (617) 253-9537
Middleton, MA
channel access reboot behavior Brian McAllister
Prev: RE: channel access reboot behavior Jeff Hill
Next: Linux GNU Tool Chain for Tornado 2.0 available Ernest L. Williams Jr.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
