1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: how to handle periodic bad readings and alarms
To: [email protected]
Date: Fri, 18 Jan 2002 10:05:32 -0600
Yesterday one of our busses went partially bad. Every few seconds the readings from all devices from the bus would indicate that there was a read error. Then the next read would succeed. One suggestion to handle these situations was to only signal an error afer N number of bad readings in a row. Has anyone attempted to handle this situation with EPICS? Any suggestions?
I know that the correct way to handle this is fix the problem ASAP but I don't enjoy calling in a support team in the middle of the night.
Thanks for your comments.
Geoff
Prev: Re: PV CAS Gateway Problem Ralph . Lange
Next: IOC mesage at startup john sinclair
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: betrothed to VAXC? Jeff Hill
Next: RE: how to handle periodic bad readings and alarms Allison, Stephanie
