1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: URGENT!
To: <[email protected]>
Date: Fri, 15 Feb 2002 10:25:29 +0530
 Sir,
         I would like to know whether you can provide card solutions meeting
the following requirements.
      1)    64KB SRAM.
      2)   128KB EPROM.
      3)   Two asynchronous serial ports and baud rate generators for the
serial ports.
      4)   One timer/counter
5)	62  independently configurable I/O lines of which 12 are input lines ,and
50 are output lines.
6)	6U single slot solution.
7)	WINDOWS OS
8)	Available in extended temperature range.
If available , kindly inform me the same and the approximate cost of the
card at the earliest.
        SABU C. VARGHESE
        MANAGER
        SPG, KELTRON
        TRIVANDRUM
        KERALA - 695 564.
        Phone: 0471-888763(302)
        Fax:  0471- 888736
Prev: iocLogServer - doubled messages Brian McAllister
Next: Problem building 3.14 application with ipac/CANbus Rarback, Harvey
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <2002>  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
