Thanks to all who replied!
The changes are in, only time will tell now.
BTW, I found the command: epicsPrtEnvParams
which lists all the environment variable settings for the IOC.
Thanks again!
Kevin
> -----Original Message-----
> From: Brian McAllister [mailto:[email protected]]
> Sent: Thursday, March 21, 2002 6:27 AM
> To: Kevin Tsubota
> Cc: [email protected]
> Subject: Re: EPICS iocLog file size limitation
> >>> On 3/20/2002 at 18:07:11 -1000, Kevin Tsubota wrote:
> > We just recently upgraded to our host to Solaris 8 and
> noticed that our
> > EPICS iocLog files are limited to 1MB with the data being
> over written
> > from the top. We have a number of other files that are
> greater than
> > 1MB being written by non-EPICS systems in the same
> directory. Prior to
> > this we were running SunOS 4.1.4 hosts and have iocLogs > 1MB.
> The limit is in iocLogServer, and is controlled by the
> EPICS_IOC_LOG_FILE_LIMIT, which normally defaults to 1MB.
> You can either
> change the default (CONFIG_SITE_ENV in $EPICS_BASE/config is the right
> place for that) or you can set it in the environment before
> you start the
> logServer.
> Brian McAllister Controls Programmer/Beam Physicist
> [email protected] MIT-Bates Linear Accelerator
Updating R3.13.5 to R3.13.6 Ralph . Lange
Re: EPICS iocLog file size limitation Jim Thomas
<2002>
2025
2026
Re: EPICS iocLog file size limitation Steve Lewis
<2002>
2025
2026
