> Hello Fritz:
> I completely agree with your idea but wonder about the implementation.
> menu(aoDRLM) {
> choice(aoDRLM_Clamp,"Clamp")
> choice(aoDRLM_Reject,"Reject")
> works for setting bit 0 to Clamp/Reject.
> But how would you define the menu so that other bits
> are included?
> Assume bit 1 would define the "X" behavior, this works:
> menu(aoDRLM) {
> choice(aoDRLM_Clamp,"Clamp, No X")
> choice(aoDRLM_Reject,"Reject, No X")
> choice(aoDRLM_X_Clamp,"Clamp, Use X")
> choice(aoDRLM_X_Reject,"Reject, Use X")
> But using menus for fields where each bit has a meaning
> soon becomes awkwards.
> -Kay
Kay,
Well, this is where the concept has a few rough edges. To use a
menu to assign the possible values it would be necessary to have an
identifier string for every possible combination of bits. For more
than a few bits, this is prohibitive. In the cases where I have used
a mode field, I have made it an integer or short integer and assigned
a hexadecimal value in the record instantiation.
Fritz
- Re: AO Record: New Drive Limit Mode? Bernd Schoeneburg
Re: AO Record: New Drive Limit Mode? Bob Dalesio
RE: NAN and INF Rarback, Harvey
<2002>
2025
2026
Re: AO Record: New Drive Limit Mode? Jim Thomas
<2002>
2025
2026
