I have a monitoring problem in our EPICS system. Someone (probably)
is turning on the pulser calibration mode for part of the muon system
in the D0 detector. I want to find out if this is happening through
the EPICS system or via one of the several other paths of destruction
that the hardware types leave for themselves.
So, we set up a channel archiver to watch for changes in the value
field of the EPICS longout record that is connected to the hardware
control register. This record has the SCAN field set to "Passive";
so, it will only process when the VAL or PROC fields are written.
Unfortunately, the archiver will only see changes of value and, if the
same bit pattern is written to the record's VAL field, the archiver,
which is using a monitor, will not record the transaction because the
value does not change.
Well, when the record processes, for whatever reason, the value of
the timestamp changes and I can just archive changes in the TIME
field. Well no! Someone decided that the TIME field should have the
DBF_NOACCESS property (it seems to me that SPC_NOMOD would have been
adequate to protect the timestamp, but perhaps there are other
considerations) and, so, the archiver cannot connect to it.
This leads to the question: How can I archive an entry every time
that an output record processes?
Fritz
BACnet Rolf Keitel
Re: Archiving when a record processes Ned Arnold
<2002>
2025
2026
BACnet Rolf Keitel
<2002>
2025
2026
