Subject: |
A perl *.sch to *.db converter (utility for capfast) |
Goetz Pfeiffer <[email protected]> |
To: |
[email protected] |
Date: |
Thu, 13 Jun 2002 12:33:49 +0200 (METDST) |
I would like to announce Sch2db.pl. This is a perl-script
that converts capfast drawings (*.sch - files) directly to
the epics db-format (*.db files).
By using this script, sch2edif and e2db are no longer needed.
You can convert your capfast files without the need to have
capfast or the capfast license-server installed on your system.
However, this script needs the capfast symbol-files (*.sym). The
path to these files can be given on the command-line or can be
hard-coded into the script (look for "$opt_sympath"...).
The script has a short help-text which can be seen with
"./Sch2db.pl -h"
The no-defaults ("-n") option can be used in order to see
at a glance, what a capfast drawing really defines, by omitting
all default-values and just showing fields that are set to a
specific value. Together with "dbdiff" I use this to have a kind
of "diff" utility for capfast files.
Benjamin Franksen ([email protected]) has modified
"makeBaseApp.pl" here at BESSY in order to use Sch2db.pl instead
of sch2edif and e2db during make.
The script has been tested with most of the capfast-drawings here
at BESSY and converts them the same way the combination of
sch2edif and e2db does.
The script can be found at:
http://www-csr.bessy.de/~pfeiffer/perl/Sch2db.pl
I hope somebody finds this software useful.
Suggestions or comments are welcome.
greetings
Goetz Pfeiffer ([email protected])
Real-time data correlator ready for beta test Peregrine M. McGehee
EPICS 3.14 question john sinclair
<2002>
2025
2026
RE: A perl *.sch to *.db converter (utility for capfast) Redman, Russell O.
<2002>
2025
2026
