1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: GreenSpring memory
To: John Faucett <[email protected]>
Cc: [email protected]
Date: Mon, 01 Jul 2002 10:07:36 +0200
Hi John,
I had a similar problem with the ipOctal card when I have alse an TEWS
Tip810 canbus card on a 162. The one address which is used to map the interrupt vector of the ipOctal card does not seem to be setup in the
mapping registers to point to the internal address on the IP card, but
rather seems to be mapped to VME space. I put an external memory card
in the crate and the problem goes away.
Looks like the mapping register setup is done in a separate thread and
not finished yet when the drivers try to access the registers.
Burkhard
Re: GreenSpring memory Andrew Johnson
GreenSpring memory John Faucett
Prev: Re: waveform calculations Peregrine M. McGehee
Next: Re: GreenSpring memory Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: GreenSpring memory John Faucett
