In tracking down an apparent channel access failure, we
discovered that the terminal server driver (tnetDrv) behaves
badly when the addressed terminal server port is logged out.
Specifically, the combination of the default high priority
(3) of the tTnet task coupled with the lack of a timeout
argument in the following causes the IOC to lock up.
if (select (FD_SETSIZE, &readFds, NULL, NULL, NULL) == ERROR)
logMsg ("tnetDev: ERROR--select 0x%x\n",
getErrno, NULL, NULL, NULL, NULL, NULL);
break;
Deletion of the tTnet task restored both channel access and
telnet communications.
We will add a default timeout argument to this select call - unless
other tnetDrv users have already done so.
- Peregrine
Peregrine M. McGehee (505) 437-6822
Sloan Digital Sky Survey Apache Point Observatory
Re: GreenSpring memory Andrew Johnson
Re: waveform calculations Alexei Dmitrovski
<2002>
2025
2026
3.14 vs g++ Jim Thomas
<2002>
2025
2026
