1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Acromag IP 330 External Triggering
To: [email protected]
Date: Mon, 22 Jul 2002 10:05:34 -0400
Has anyone succeeded in getting external triggering to work with the IP330?
We are using the EPICS driver by Mark Rivers, which appears to support it at least to the point of setting the control registers. The hardware works in "Burst Continous", as the 5Vpp, .5Hz square wave signal hooked up properly reads between 0V and 5V. When the same signal is applied to the trigger input, the startup file configuration set to 5 for External Triggering and the direction to "Input", the value read is somewhere around -4.9xxxx. The value does change sometimes, but the time period seems random.
The coax leads are hooked up to 1,2 for chanel D00, and the external trigger is hooked up with + at 49 (ext trig) and - at 39 (common). The hardware setup (leads and registers) seems to be right, so I think the problem is somewhere in the EPICS side of things, which I am not very familiar with. Currently it is using the Ip330Scan application, should it be using something else?
Eric Snow
Accelerator Physics
Spallation Neutron Source
Oak Ridge National Lab
[email protected]
Prev: How to set the correct IOC time Cheng Weixing@ssrc
Next: Re: TCP/IP driver for RGA Rolf Keitel
Index: 1994  1995  1996  1997  1998  1999  2000  2001  <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: How to set the correct IOC time Pete R. Jemian
